Alternative to FoxESS-Modbus which supports Forced Charge on KH7 inverter?
I am running the FoxESS-Modbus integration with my FoxESS KH7 inverter. When a work mode of “Force Charge” is selected in the integration the inverter responds by going into Backup mode, and does not then behave as desired. There is a “Forced Charge” mode available in the Mode Scheduler for the inverter, but FoxESS-Modbus doesn’t seem able to select it.
Is there an alternative to the FoxESS-Modbus which will put a KH7 inverter into “Forced Charge” when required?
