Always On Display - Enable/Disable via automation
I was hoping that someone with more in depth android knowledge might help me out with this.
I’m using an automation, that amongst many other things, mutes my phone for the night and turns the volume back on when I wake up using the command notifications. I would like to add a similar function, that does the same with the always on display mode. I can’t sleep with any light sources nearby, so currently I rely on Samsung’s built in time based functionality, which turns off AOD after a set time, however I’m not going to sleep at the same time all the time. Is it possible to use a command notification for this as well?
I know that do not disturb mode can be used instead, however I wouldn’t like to use that.
