This project modernizes the setup to allow configuration through the GUI and autodetection on the network using mDNS/zeroconf. Features for the camera are automatically determined by polling the camera capabilities and creating the relevant entities.
It can be installed through HACS and replaces the default integration.
I just added this integration to my Home Assistant. I have 2 cameras connected and it detected both. Added the first camera without issue, but the second gives “an unknown error occurred” I’m sure I used the right userid/pwd combination, verified by browsing to the camera directly. I’ve looked in the LogBook and in the logs - nothing displayed there. Tried using the “Add Device” button from the Amcrest integration screen - nothing happens when I click on the button.
Ideas? Suggestions?
I have installed this integration, and HA does discover my 4 cameras. However, I cannot login to any of them (I do have the correct credentials). I get the following error message, which is useless:
They do not use the standard 80 port. IF I try to add them manually, specifying the IP and port, I get the same error message. Any idea how I can add them to HA? They used to work well previously without this integration.
