This one :
climate:
- platform: awesome_thermostat
heater: climate.climatisation
target_sensor: sensor.climatisation_temperature
eco_temp: 18
away_temp: 16
boost_temp: 22
comfort_temp: 21
sleep_temp: 20
This one :
climate:
eco_temp: 18
away_temp: 16
boost_temp: 22
comfort_temp: 21
sleep_temp: 20
Hello @meepmeep
Awesome Thermostat is based on the generic thermostat integration which take a switch as heater, not another thermostat.
I have in mind to encapsulate other thermostat to decorate basics ones with the awesome features (open close doors, movement). But I don’t know when I will have the time to do it.
Regards
Hi.
Does that mean i cant use heater: climate.* ?
I wanted to test it with my Homematic IP thermostats, but that doesn’t seem to work.
climate:
heater: climate.kueche_heizungssteuerung
target_sensor: sensor.lumi_lumi_weather_temperature
eco_temp: 18.5
away_temp: 16
boost_temp: 23
comfort_temp: 21.5
sleep_temp: 20
@dadge thank you for the head’s up. I skipped the generic thermostat and jumped directly to yours, but indeed I need a simple switcher (maybe I can create one from a helper)
Hi all,
This integration seems no more maintained. For this reason I have first made a fork and then add many enhacements so that I had to rename and rework totally the integration. It is available here: GitHub - jmcollin78/versatile_thermostat: A full featured Thermostat for Home Assistant: presets, window, motion, presence and overpowering management
Your feedback will be appreciated !
