I just updated to 2021.4.0 and from what I read I should have the possibility to configure the analytics reporting from the Configuration->General tab.
But when I go there, I see no section for Analytics.
Is there a simple explanation/solution to this? I’ve tried re-reading the analytics documentation, but cannot see anything there.
A potential cause for this is if you forgot your password at some point and followed the old instructions which involved creating a new user account (that’d be created as “admin” and not “owner”).
You could try fixing that at the .storage/auth file. You’d want to find your account and change is_owner from false to true. Edit at your own risk and make backups first etc if you decide to go that route…
Or an easier method would be to just wait for the next patch release. That’s going to make the analytics settings available to administrator accounts too.
Right.
It turns out I no longer had an ‘owner’ in my system. Edited the auth file and now I have the analytics config. This should perhaps be mentioned in the documentation.
Thanks.
ah you mean a manual verification. Well I did that and it was true, but I double checked it again and it is changed back to false, so I will try to change it when ha is stopped.
