I recently upgraded to a Pixel 10 and have found that the Home Assistant companion app is not using the system font (Google San Flex). Instead, it is using Roboto. I know I can set a custom font for the dashboard, but this is not enough.
How do I make the companion app use the system font (Google San Flex) throughout the entire app? And why does it not do so by default?
Since Google Sans Flex is open and on Google Fonts, load it as a web font and override HA's font app-wide with card-mod (HACS). You won't be using the phone's actual system copy, but the Google Fonts version is the same font.
# themes.yaml
Google Sans Flex:
card-mod-theme: Google Sans Flex
card-mod-root-yaml: |
@import url('https://fonts.googleapis.com/css2?family=Google+Sans+Flex:opsz,[email protected],100..1000&display=swap');
html {
--mdc-typography-font-family: "Google Sans Flex", "Roboto", sans-serif;
--paper-font-common-base_-_font-family: "Google Sans Flex", "Roboto", sans-serif;
--paper-font-body1_-_font-family: "Google Sans Flex", "Roboto", sans-serif;
Pick that theme in Profile → Theme. It applies in the app and any browser, since it's a frontend theme. (Grab the exact @import URL from the Google Fonts specimen page, and check card-mod's "themes" docs for the current root syntax.)
Why it's Roboto by default: the Companion app is a WebView wrapping the HA web frontend, and that frontend bundles Roboto and hardcodes it in its CSS (deliberately, so HA looks identical on every browser/OS). So it renders Roboto because the web UI asks for it, not because the app ignores your Pixel's system font. There's no "use system font" toggle, and a WebView can't reach the OS UI font directly anyway.
Honest caveat: a few parts of HA still hardcode Roboto (entity badges, logbook, history, some card titles) and don't read the theme variable yet, so expect ~95%, not pixel-perfect. For stubborn spots, a blanket * { font-family: "Google Sans Flex" !important; } in the card-mod root catches most stragglers.
Thank you so much the detailed and helpful response!
