Android IP Webcam Integration Failed to Connect
I’ve been trying to add the Android IP Webcam integration, but only get Failed to Connect error. I’ve tried everything I’ve found, unfortunately the HA integrations page for this integration falls short with guidance.
I’m using the Android IP Webcam app on a Nexus 7 device. Video from the camera is streaming nicely to an IP on my local network. I’ve enabled logging and sensors show up well on the /sensors.html page, so I know its working correctly.
I’ve attempted to add configuration to my configuration.yaml file following several suggestions from posts, but none can get the integration to get passed the “Failed to Connect” error.
Would appreciate any guidance or suggestions.
Hi all,
I do have the exact same problem as described. Anyone any Idea on how to fix it?
