I have Thread network running on HA using the OpenThread Border Router add-on with a ZBT-1. I am able to add matter over Thread devices to HA using my android phone (Pixel 10 pro xl) without any issues, but then when I try to see said Thread network on the same phone (through the phone’s settings nothing shows up). Should I be concerned? I’ll give some context / more info. I used to have a Homey Pro with it’s own Thread network which I eventually factory reset and sold it. At first I couldn’t add devices Thread devices to HA which eventually was resolved by me resetting Google Play services (guess it was holding on to the old Homey Pro thread network) and was causing some conflicts. I’ve also performed the “Sync Thread credentials” from the troubleshooting section of the android app. Is this a real concern or not?
I seem to have the same problem, the Thread Network settings see the DIRIGERA Thread network (which I don’t really want), but not the HA one, even if I did use the Troubleshooting → Sync Thread Credentials which apparently finished correctly. In HA, I do see both networks, with the ha-… set as the primary one.
This is a problem for me, I think, because it means that I cannot make my DIRIGERA join the ha- thread network.
Does not really help, but I tried something else:
When I unplug the DIRIGERA, then add a newly reset device via Google Home, it will work via the HA OTBR, even with it not appearing in the Thread network settings of the device. When adding a newly reset device when the DIRIGERA is plugged in, it will go via the DIRIGERA network.
