Anyone have a clue why my Nvidia Shield keeps disconnecting every few minutes? I have firetv sticks as well but they seem to work fine and are setup exactly the same. I am running haac in a virtual machine in ubuntu using the integrated python adb.
I don’t see the same issue on my Shield and I am using the “androidtv” integration.
Are you able to post your config?
On the other hand, I believe you can use the Google Cast integration, as the functionality is supported by the Shield (and this integration can be setup from the Integration area in the configuration).
yeah here is my config for the androidtv’s. The top one is the Shield, the only one I am having issues with. I might try the Google Cast integration to see if that works better.
media_player:
# Use the Python ADB implementation
- platform: androidtv
name: Living room TV
host: 192.168.50.159
device_class: androidtv
get_sources: false
host: 192.168.50.94`
host: 192.168.50.93
Hi, did you work out what the problem was ?
I’m guessing something in the ShieldTV’s config ?
