DnbSTEb
(DnbStEb)
February 5, 2026, 7:27am
1
Im trying to use a blinking effect for a specific image inside a picture elements card. I already have a working card_mod part where the picture uses an input_boolean for the opacity but the animation won’t work.
Is there any way for it?
Here the yaml from my dashboard
- type: image
card_mod:
style: |
hui-image {
{% if is_state('input_boolean.dummy_xyz', 'on') %}
opacity: 1;
animation: fade 1.5s ease-in-out infinite;
{% else %}
opacity: 0;
{% endif %}
@keyframes fade
0% { opacity: 1; }
50% { opacity: 1; }
10% { opacity: 1; }
image:
media_content_id: /local/folder_x/folder_y/picture_z.png
style:
left: 72.85%
top: 69.35%
width: 2.25%
rotate: '-16.8deg'
It cannot be called “working” since it is wrong(.
Besides, indentation is broken.
You are missing “keyframes” options.
Check for other examples for animation: main card-mod thread - 1st post - link at the bottom - Entities card - animation
DnbSTEb
(DnbStEb)
February 5, 2026, 8:06am
3
I accidentally forgot to copy the @keyframes fade line. And changing the opacity of the image with the input_boolean is working.
I checked nearly every post with card_mod, styling etc that’s why I created a extra topic because I can’t figuere it out
The updated code is still wrong - no closing bracket, broken indentation.
No need to check “any”, check proven ones - use a path to examples which I suggested.
Take this as a schema:
@keyframes abc {
xxx {...}
yyy {...}
DnbSTEb
(DnbStEb)
February 5, 2026, 8:16am
5
card_mod:
style: |
hui-image {
{% if is_state('input_boolean.betriebsrestaurant_dummy_storung', 'on') %}
opacity: 1;
{% else %}
opacity: 0;
{% endif %}
@keyframes fade {
0% { opacity: 1; }
50% { opacity: 0; }
100% { opacity: 1; }
I shut my mou…
Yes sometimes it needs a second person to see things I oversee…
Thank you
Too little of morning coffee)))
Best wishes!
