Just trying to install this :GitHub - chazzu/hass-animated-scenes: Custom component for Home Assistant which allows you to create animated color and brightness scenes with many options.
on docker :
download zip file,
unpack it on desktop
now in docker home assistant folder (yes where is yaml files)
add a folder named custom_components
here COPY “animated_scenes” folder (unpacked before), and leave the 7 files out of that, (but in Custom_components folder).
|-custom_components
|- png , psd, gitignore… 7 files
|-- animated_scenes
Restart Home Assistant,
and now " In Home Assistant, go to Settings → Devices & Services. Click Add Integration
- Select the Animated Scenes integration."
Finally you can see “Animated Scenes”
Now the question :
ok BUT Where to enter the infos for colors ?
on the automation i read only :
- color_type: rgb_color
color:- 255
- 0
- 0
brightness: - 0
- 255
one_change_per_tick: true
nearby_colors: 0
weight: 10
where I put : ?
transition: [1, 4]
change_frequency: 5
change_amount: 6
Am I missing something ?
