Annual Date Range Binary Sensor
Creates a binary sensor whose state is “on” between the defined start and end dates.
This can be used to define your own custom “seasons” to use as conditions for lighting effects, electricity tariffs, holidays, sports seasons, etc. Date spans that cross over New Year are supported.
Changelog:
  • 2025-12-17:
    • Updated to handle date strings with or without the year and either - or / separators.
blueprint:
  author: Didgeridrew
  homeassistant:
    min_version: 2025.10.6
  name: Annual Date Range Binary Sensor
  description: |
    Creates a sensor whose state is "on" when the current date is between two static dates.  Crossing the new year is supported.
  domain: template
  input:
    start_date:
      description: |
        The date (YYYY/MM/DD or MM/DD) you want to be the first day of your range.
        The resulting binary sensor will turn "on" at 0:00:00 on this date.
        The year will not be used for this binary sensor.
      selector:
        date:
    end_date:
      description: |
        The date (YYYY/MM/DD or MM/DD) you want to be the last day of your range.
        The resulting binary sensor will turn "off" after 23:59:59 on this date.
      selector:
        date:
variables:
  _start_date: !input start_date
  start_l: |
    {% set sep = '-' if _start_date is search '-' else '/' %}
    {% set d_list = _start_date.split(sep) %}
    {% set ymd = d_list | count %}
    {{ (d_list|map('int',0)|list)[ymd-2:ymd] }}
  _end_date: !input end_date
  end_l: |
    {% set sep = '-' if _end_date is search '-' else '/' %}
    {% set d_list = _end_date.split(sep) %}
  crosses_year: "{{ start_l > end_l }}"
  current_l: "{{ [now().month, now().day] }}"
  - trigger: homeassistant
    event: start
  - trigger: time_pattern
    hours: /1
binary_sensor:
  state: |
    {% if start_l == end_l %}
      {{ start_l == current_l }}
    {% elif crosses_year %}
      {{ start_l <= current_l or current_l <= end_l }}
    {% else %}
      {{ start_l <= current_l <= end_l }}
    {% endif %}
  availability: "{{true}}"
Template Blueprints are currently (October 2025) only available through YAML configuration. You can find more details about how to use them at:
HA Docs - Templates - Using Blueprints
Once you have installed the blueprint, use the following examples to help set up your own Sensors in your configuration files.
Configuration Examples:
template:
  - name: Twelve Days of Christmas
    unique_id: bp_12_days_xmas_0001
    use_blueprint:
      path: Didgeridrew/annual-date-range-binary-sensor.yaml
      input:
        start_date: "2025/12/25"
        end_date: "2025/01/06"
template:
  - name: Halloween Lights Season
    unique_id: bp_halloween_days_0001
    use_blueprint:
      input:
        start_date: "2025-10-20"
        end_date: "2025-11-05"
template:
  - name: Christmas Lights Season
    unique_id: bp_xmas_lights_days_0001
    use_blueprint:
      input:
        start_date: "12/1"
        end_date: "1/6"
While it is not the original intent for this blueprint, it can also be used for single-day holidays, anniversaries, or birthdays by setting the same value for both start_date and end_date:
template:
  - name: Valentines Day
    unique_id: bp_valentines_day_0001
    use_blueprint:
      input:
        start_date: "2/14"
        end_date: "2/14"
This post has been set to Wiki mode. Feel free to add further examples if you think other users would find them helpful.
