let me know if you need any logs or anything…#like i said…not only happening with ikea but also innr and osram.
what ever support i can give just ask please.
and a thanks for all the work put in!
Wonderful!
don’t mean that I’m not happy with your component for the moment but using official supported component would be great. If it support all your features of course.
if you need beta testers just say the word.
I have no problem with my osram bulb, for months
How to manage group with zigpy ?
Does it change entities name ?( If I need to change all my automation)
If you need beta tester …
Looks interesting… But what does it actually control?
Seems it could be used to control wired products through ZigBee?
Yes it’s similar to popular zwave micro modules you can put behind a standard wall switch to controll a light for example.
The issue here is that I was not able to find any documentation regarding the product and more important the size of it. On picture it looks really big.
So I order one piece and will see the result… in few weeks then.
The webpage says:
Caution: This product must be used with a gateway and there must be a neutral line.
Product Size: 49.3 * 46 * 24mm
Input voltage: 100-250 V, 50Hz
Maximum load: 10A / 2500 W
Operating temperature: -10 ℃ ~ + 50 ℃
Operating Humidity: 5% ~ 95% RH
Sounds like the size is ok for a wall socket.
Could you possibly describe what this means? How do your Zigate component, zigpy and zha work together?
Also, I heard Zigate can listen / connect to multiple channels?
I love your component. All my Xiaomi stuff was automatically detected, including the multiclick buttons and it just works. Great work!
It means we can use the official zha component instead of mine.
In that case all the job is done by zigpy and the zigate itself is just a zigbee serial adapter
My alternative for the same purpose but not zigbee was a shelly.cloud dual module.
39x36x17
Because I always have tons of cables behind these wall switches.
This is awsome!
hello @doudz
somethings change in the lib ?
Everythings has been working great before i upgrade the component and home assistant.
After some time we can have to do again the process …
Does using zigpi will move all process from zigate to host ( computer ) ? i think zigate is not powerfull enought.
EDIT 1 : now everything seems working now … really strange. I thinks zigate is a bit laggy
Is the integration already available in public HA?
There is no ZiGate in radio device selection.
When I try to configure ZHA as single plugin to manage ZiGate and select ezsp ad radio device, HA stops staring.
Any additional steps needed, beside adding ZHA entries to configuration.yaml?
zha:
usb_path: /dev/ttyUSB0
database_path: /config/zigbee.db
The zigbee.db is initiated - some binary content is present, after HA restart.
Integration in zha is not yet public. And it require a custom zigate firmware because the current 3.0f doesn’t have the needed raw mode.
It should be available in the next firmware release
zigate could be “laggy” if you or the component send too much request in a short time.
I had these kind of issues when I send discover_device request multiple times without waiting the end of the previous request.
Great, I’ll wait for it impatiently
In the meantime, I’m using Your’s latest component version.
When I add multisensor module (ie. Aquara temperature-humidity-pressure) is there any way of automatically rename sensor entities to match the one that I give to module?
After adding I get naming similiar to:
module: lumi.weather [id]
What I (and probably most of us) want is:
module: room
You could rename from HA directly
I know about that.
But I deeply dislike the idea of changing the name 4 times for each sensor module (1 for module, and then for each sensor).
I can easily write a script for that, if only these entities were stored somewhere in accessible form.
I don’t know if you can do it automatically
IMHO it’s not a big deal since you do it one time and that’s all for life
