DATA RECEIVED IN GROTT!
Thank you so much for your help!
Great…good luck then with the rest, you can still proxy-forward to the growatt-server.us so your app still can see what is happening.
Yeah, my setup allows to connect to the repeater and have 10.x address and I can connect to the internet fine…the other way round is not working, i.e. to get to the shine dongle I need to be on the 10.x segment
How do I set up the proxy forward? I just want to check that it’s still working on the ShinePhone app
in the grott.ini (see the manual), I am using the server-us ip (ip=47.251.35.20)
Sorry I’m being a total noob. How do I read/edit the .ini file?
install the addon file editor and then you should be able to see the folder in which the grott.ini is placed (or you create it…see the docs)
EDIT you can also install visual studio but that is kinda heavy for simple text stuff
And can you please mark the post on aligning segments as the solution, makes it easier to find when someone reads this post
