Hello, I have these two automations to switch on my heating system in a second residence to avoid water pipes to freeze with a sonoff TH16 thermostat and a sonoff switch:
- id: '1611511929627'
alias: Avoid freezing on
description: ''
- platform: numeric_state
entity_id: sensor.thermostat
below: '5'
condition: []
- service: switch.turn_on
data: {}
entity_id: switch.sonoff_1000a0eba5
mode: single
- id: '1611511341689'
alias: Avoid freezing off
description: ''
attribute: unit_of_measurement
above: '7'
condition: []
- service: switch.turn_off
data: {}
mode: single
The problem with this is if I want to warm the house to live in, with the second automation activated, the heating switch is set off when the temperature is above 7 degrees, and of course that’s not the desired behaviour. I want to remain on until maybe 22 degress.
Does anybody know how could I automate this behaviour without deactivating the ‘Avoid freezing off’?
TIA
Miguel
I forgot to say that, when I want to get the house warm, I manually switch-on the switch. So, what I’d like is that when I switch It manually on, the automation does not work until I manually switch the heating off again.
Rather than have the ‘off’ automation trigger at a temperature, have it as part of the automation that triggered because it dropped below 5…
below: 5
- wait_template: "{{ states('sensor.thermostat')|int > 7 }}"
timeout:
hours: 2
continue_on_timeout: true
Thank you for the reply
I have a doubt. What is the efect of the timeout? I mean, what happens if in the 2 hours span the temperature is still not above 7 degrees? I suppose the heating will set off after this time in any case.
And what would be the effect if no timeut is set in the automation?
Yeah, it will timeout at 2 hours and switch off, it’s just a failsafe really in case there’s some kind of fault with the system. I set it at 2 hours on the basis that I guessed it would take no more than about an hour and a half, and then lobbed another half hour to be sure. So long as the temperature has gone over 5 again the automation will trigger again when it drops below again, and of course if it doesn’t get from 4.9 to 5.1 in 2 hours then there’s no point in it triggering again because it’s broken. But if you think that’s too short (because from prior knowledge it takes a long time to get to 7.5) then obviously change it to 3 or whatever.
