Any hope for this HSM200?
I’ve followed the directions here. HSM200 User Guide
The sensor resets fine, blinks blue for inclusion, but HA never finishes including the device. Tried several times with and without “secure if possible” option enabled.
2026-02-01 14:56:26.415 CNTRLR   The inclusion process was stopped
2026-02-01 14:56:26.417 CNTRLR   finished adding node 117:
                                   basic device class:    Routing End Node
                                   generic device class:  Notification Sensor
                                   specific device class: Notification Sensor
                                   supported CCs:
                                   · Z-Wave Plus Info (0x5e)
                                   · Notification (0x71)
                                   · Multilevel Sensor (0x31)
                                   · Color Switch (0x33)
                                   · Multilevel Switch (0x26)
                                   · Manufacturer Specific (0x72)
                                   · Version (0x86)
                                   · Association Group Information (0x59)
                                   · Association (0x85)
                                   · Configuration (0x70)
                                   · Node Naming and Location (0x77)
                                   · Device Reset Locally (0x5a)
                                   · Firmware Update Meta Data (0x7a)
                                   · Powerlevel (0x73)
                                   · Security 2 (0x9f)
                                   · Transport Service (0x55)
                                   · Supervision (0x6c)
                                   controlled CCs:
2026-02-01 14:56:26.418 CNTRLR » [Node 117] Assigning SUC return route...
2026-02-01 14:56:26.418 CNTRLR » [Node 117] Deleting SUC return route...
2026-02-01 14:56:37.262 CNTRLR   [Node 117] Timed out while waiting for a response from the node (ZW0201)
2026-02-01 14:56:37.262 CNTRLR   [Node 117] Security S2 bootstrapping failed: did not receive the node's desire
                                 d security classes.
2026-02-01 14:56:37.263 CNTRLR   [Node 117] has failed S2 bootstrapping and cannot be interviewed
I have found when they work they are great device. I have to that have included and another two will at best add as an unusable node. Sorry I am no help
