I am using the crowdsec add-on. It stores its data in a sqlite DB.
I would like to analyse said DB with another add-on called Metabase.
It doesn’t have to be the live DB, happy to have a daily automation copy it then run and extract stats with Metabases from it.
Any ideas, how and where to do this, I mean is there a shared folder all add-ons can access? Kind of one would mount a volume into a docker image or similar?
I’m no expert on any of this, but if crowdsec can be told to use an external database, like mariadb, there is an add-on for that and you could then log into mariadb from the other add-on.
Brilliant idea, thanks. Crowdsec can indeed use a different DB, leaving this link here in case someone else finds his way to this thread: Databases | CrowdSec
Its easily doable since my HA instance also uses PostgreSQL.
