I am troubleshooting a problem but at the moment I think I have some SCreek devices flooding home assistant and causing short inturruptions in sensing.
So I did some searching and it points to their device's sensors.
Looking at the logs - every 100-200ms, I have multiple Screek sensors sending the exact same TextSensorStateResponse with key 2896559318 and state "null". These may be flooding my event bus.
The debug logs were just full of a flood of repeat sensor messages.
- 5 different Screek sensors (f2-d131bc, f2-d169c8, f2-501a28, f2-d143b0, plus l13-4131f0)
- Each sending every 200-300ms the same "null" text sensor update
- That's 15-20 updates per second just from these text sensors
The key 2896559318 appears to be a text sensor that Screek firmware uses for something like "LD2410 Debug" or "Radar Raw Data". Even though it reports "null", ESPHome may still be processing it and sends each update to HA.
I don't use ESP Home Builder because I'm not that familiar with ESP Home and I haven't need to. But I installed it and these devices don't show up there. I see my 7 Apollo Automation sensors, but not the SCreek ones.
So I don't know if I have any way to modify the way ESPHome sends messages. Logging is not the issue. I've used my configuration.yaml file to block writes to the logs, but the messages are still being process.
Does anyone have any ideas? I'm using HAOS, 2026-6.
