Any way to monitor Dasher Process?
Is anyone using the systemmonitor platform to monitor Dasher? I am monitoring mosquitto and homebridge fine but can’t figure out how to monitor the Dasher process. Open to suggestions. Thanks.
CARLO.
https://github.com/CCOSTAN/Home-AssistantConfig/issues/173
for me Dasher runs under the node process.
- type: process
  arg: node
sorry for the multiple edits. To change the process name from node to dasher check out the pull request I just made.
https://github.com/maddox/dasher/pull/78
Also just to make a suggestion you can take these lines
and clean them up with .
value2: "{{ trigger.to_state.name }} is "
That works well. Thanks for the clarification AND the additional Code Clean up! Appreciate it.
edit: I actually went with trigger.to_state.attributes.friendly_name :wink:
