Hi!!!
I just upgrade hassbian to 0.69 and I found a new template call Fan Template https://www.home-assistant.io/components/fan.template/
I’m trying to config this with my fan but I don’t know how to create a script for speed services. does anyone using this template, can you share a sample code for me…
Thanks!!!
petro
(Petro)
May 14, 2018, 11:54am
2
That depends on your fan. Every fan will be different. Do you have a fan that has adjustable fan speeds that does not come through as a fan in HA?
Does anyone have more detailed examples of the template fan component. I currently control my fans with scripts for each speed and one for off.
petro
(Petro)
May 25, 2018, 3:12am
4
I’d be taking a guess at how it works, but If you post your scripts I can piece it together how I think it works.
Let me explain that better I use scripts with an input selector. I have a pilight switch with the raw protocol setup for each fan speed and I trigger the switch with the input selector which calls a script.
An example switch:
platform: pilight
switches:
patio_fan_lights:
on_code:
protocol: raw
code: 350 665 385 315 735 315 700 315 700 665 350 350 700 350 700 350 700 350 700 700 350 700 350 350 700 12110
off_code:
protocol: raw
If the template fan component requires a python script I could probably figure that out.
petro
(Petro)
May 26, 2018, 12:48am
6
for you i think it would work like this:
fan:
fans:
bedroom_fan:
friendly_name: "Bedroom fan"
value_template: "{{ states('switch.patio_fan_lights') }}"
turn_on:
service: switch.turn_on
entity_id: switch.patio_fan_lights
turn_off:
service: switch.turn_off
set_speed:
data_template: >
entity_id:
{% if speed == '1' %}
switch.patio_fan_slow
{% elif speed == '2' %}
switch.patio_fan_medium
{% elif speed == '3' %}
switch.patio_fan_fast
{% else %}
switch.dummy
{% endif %}
speeds:
- '1'
- '2'
- '3'
I mean, without seeing your full setup, i can only guess. But this is how i would expect it to work. I’d also need to create it myself to verify that set_speed can access the list of speeds defined in the lower section of the template.
Hope this points you in the right direction.
This is what I get.
Invalid config for [fan.template]: expected a dictionary for dictionary value @ data[‘fans’][‘my_fan’][‘set_speed’][0][‘data_template’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/fan.template/
My config looks like this:
indent preformatted text by 4 spaces
fan:
fans:
my_fan:
friendly_name: "My Bedroom fan"
value_template: "{{ states('switch.bedroom_fan_high') }}"
speed_template: "{{ states('input_select.bedroom_ceiling_fan') }}"
turn_on:
service: script.bedroom_fan_high
turn_off:
service: script.bedroom_fan_off
set_speed:
data_template: >
entity_id:
{% if speed == 'High' %}
switch.patio_fan_high
{% elif speed == 'Med' %}
{% elif speed == 'Low' %}
switch.patio_fan_low
{% else %}
switch.dummy
{% endif %}
speeds:
- 'High'
- 'Med'
- 'Low'
petro
(Petro)
May 27, 2018, 11:06am
8
thats my bad, swap the arrow spot to entity_id:
fan:
fans:
my_fan:
turn_on:
turn_off:
set_speed:
data_template:
entity_id: >
{% else %}
switch.dummy
{% endif %}
speeds:
- 'High'
- 'Med'
- 'Low'
