Hello all,
Please see the screenshot below? I’m not sure what is going on but I will explain what I believe I know. The service “esphome.supermariolight_set_light_state” seems to be left in the system from a previously deleted esp32 build.
The “esphome.esphome_web_a13b8c_set_light_state” is the service name for what I would like to be named as what was in the previous paragraph.
Is there anyway to get all of this to correct itself? i.e. get one of the services deleted and somehow refresh the other to get it named properly?
Below is my current esp build yaml:
esphome:
friendly_name: supermariolight
min_version: 2024.11.0
name_add_mac_suffix: false
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
services:
- service: set_light_state
variables:
state: string
then:
- lambda: |-
if (state == "Device OFF") {
id(button_counter) = 1;
} else if (state == "Device ON") {
id(button_counter) = 2;
} else if (state == "Device PULSING") {
id(button_counter) = 3;
} else if (state == "REACTS TO SOUND") {
id(button_counter) = 4;
// Update the sensor for Home Assistant
id(button_counter_sensor).publish_state(id(button_counter));
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Supermariolight Fallback Hotspot"
password: "pPrZpEH1vZK0"
captive_portal:
# Global variable to track the state
globals:
- id: button_counter
type: int
restore_value: yes
initial_value: '1'
# Define the GPIO output to simulate button presses
output:
- platform: gpio
pin: GPIO5 # Use GPIO5 to simulate the button press
inverted: True # Inverts the signal, making it low by default
# Template switch to simulate button presses and track the counter
switch:
turn_on_action:
- lambda: |-
// Increment the counter
id(button_counter) += 1;
// Reset the counter after state 4
if (id(button_counter) > 4) {
// Log the state with meaningful names
switch (id(button_counter)) {
case 1:
ESP_LOGD("main", "State 1: Device OFF");
break;
case 2:
ESP_LOGD("main", "State 2: Device ON");
break;
case 3:
ESP_LOGD("main", "State 3: Device PULSING");
break;
case 4:
ESP_LOGD("main", "State 4: REACTS TO SOUND");
break;
// Simulate the button press
id(simulated_button).turn_on();
delay(1000); // Simulate the physical button press duration
id(simulated_button).turn_off();
// Update the sensor value after every press
# Virtual reset button to reset the counter
turn_on_action:
- lambda: |-
// Reset the counter to 1
ESP_LOGD("main", "Button counter reset to 1");
// Optionally, update the sensor state to reflect the reset
# Expose the button_counter as a sensor to Home Assistant
name: "Button Press Counter"
lambda: |-
return id(button_counter);
on_value:
then:
- homeassistant.service:
service: input_select.select_option
entity_id: input_select.super_mario_light_state
option: !lambda |-
if (x == 1) {
return "Device OFF";
} else if (x == 2) {
return "Device ON";
} else if (x == 3) {
return "Device PULSING";
} else if (x == 4) {
return "REACTS TO SOUND";
} else {
