Anyway to replace node_id with entity_id in a set_config_parameter service call?
Is there anyway i can do this by using entity_id instead of node_id? Reason being is if I ever have to remove and add a z wave device, the node id will change. I dont want to have to remember I have to search every flow for a possible call to the old node ID and put in the new node id.
If I could use entity_id, then as long as I name the device the same when I re-add it, everything else would fall back into place.
I tried entering an entity.id in the field and removing node_id from the json, but got an API error.
The node id comes from the controller. So no, you cannot change it.
—INSERT “THE_OFFICE_MICHEAL_SCREAMING_NOOOOOO.GIF” here
