Anyway to speed up node red?
I am running NR under Home Assistant and I am experiencing 30+ second delays when Pressing Deploy after a extremely simple change - ie changed the name of a node.
The NUC that Home Assistant is running on is reporting that it is using <11% of the 16GB RAM and <7% of the processor and I have used less than 6% of the 500GB SSD.
The Deploy is set to only Modified Nodes so not sure why it takes so long to Deploy.
It is not consistent, major Node changes the Deploy is instant, change the name of the node and it takes 30 seconds.
Any ideas?
In the side panel, choose configuration nodes. You should have only 1 home assistant server.
Yup only one.
I am looking at the computer, as does not occur on other devices I have tested.
So looks local, looking at VPN as only difference on this machine
Many thanks for responding, appreciated.
