Aotech gen5 recessed door sensor missing state chages
As the title suggests, I have 3 of these gen5 recessed door sensors installed and they are mostly working as expected. However occasionally they will not correctly report the closed state after the door is closed. These are on spring loaded doors, so I suspect there may be an intermittent timing issue.
I have seen several other posts online from folks who have had similar issues with the same sensor. I haven’t seen any info to shed light on the subject. My testing has shown that the sensor is capable of handling very fast and random cycling (open/close/open/close… several times in a second and hass shows it correctly). So the problem is random, and sometimes results in annoying behavior of certain automations I have (beepers beeping even when doors are all closed). Usually I just open/close the offending door to fix it (my place is small enough where that is usually faster than using dev tools to force a changed state). Either way it’s far from ideal, but I really want to stick with these almost invisible sensors if possible (my ecobee’s are all flawless, but the magnet sensors are bulkifugly).
Anyone else experience this problem and/or know of a solution to fix it?
