ApexChart YAXIS
hello,
i need some help…
i want to setup a 2nd yaxis on the right for SolarPower, but i always get an error
/// apexcharts-card version 1.10.0 /// Multiple yaxis detected: Some yaxis are missing an 'id'.
  - panel: true
    title: MPPT Tag
    path: mppt-graph
    badges: []
    cards:
      - type: 'custom:apexcharts-card'
        update_interval: 5min
        cache: true
        graph_span: 1d
        span:
          start: day
        header:
          show: false
        series:
          - entity: sensor.solar_output_voltage
            yaxis_id: output_voltage
          - entity: sensor.solar_output_current
            yaxis_id: output_current
          - entity: sensor.solar_input_power
            yaxis_id: input_power
          - entity: sensor.solar_input_voltage
            yaxis_id: input_voltage
          - entity: sensor.solar_input_current
            yaxis_id: input_current
          - entity: sensor.solar_mppt_temp
            yaxis_id: mppt_temp
          - entity: sensor.solar_output_power
            yaxis_id: output_power
        yaxis:
          - id: output_power
          - show: true
            min: 0
            max: 400
            opposite: true
          - id: output_voltage
          - show: true
            min: 0
            max: 16
            opposite: false
          - id: output_current
          - show: true
            min: 0
            max: 30
            opposite: false
          - id: input_voltage
          - show: true
            min: 0
            max: 50
            opposite: false
          - id: input_current
          - show: true
            min: 0
            max: 30
            opposite: false
          - id: input_power
          - show: true
            min: 0
            max: 400
            opposite: true
          - id: mppt_temp
          - show: true
            min: 0
            max: 60
            opposite: false
        all_series_config:
          type: area
          curve: smooth
          extend_to_end: false
        apex_config:
          stroke:
            width: 1
          fill:
            type: gradient
            gradient:
              shadeIntensity: 1
              inverseColors: false
              opacityFrom: 0.45
              opacityTo: 0.05
              stops:
                - 20
                - 40
                - 70
                - 100
what do i do wrong?
Someone can help me?
You are creating two entries under the yaxis key. One has id: output_power and nothing else, while the other one does not have an id, hence the error. You need to combine the two:
        yaxis:
          - id: output_power
            show: true
            min: 0
            max: 400
            opposite: true
grrrrr :slight_smile:
thank you!
