Sort of confirms my experience too. Again, I think you will benefit from a utility meter for these values on monthly basis. But… if (!) the monthly values are good for every month, then I would try to fiddle with the labels instead
@sheilmann possibly your data is different? Could depend on daily stats vs. 30 min stats…just guessing loudly as no clue and tbh, very little incentive to dive deeper
Is this a different topic now or still the same issue? For having (any) consumption combined with costs/unit there are plenty of other posts outside of this Apexchart one.
Forgive my naivety but I am simply looking for a way to change the color of a graph above and below zero (for temperature). I can get the color to change using the gradient option. I have it set at .1 and 0 but this is not giving the desired effects. I just want above zero one solid color and below a different color.
You guys seem angry and wanting to appear “better” than everybody. But isn’t the point of these forums to ask for help and get it? Not be an outlet for people to belittle other people. I mean, in my field I help people in the forums. But if you are just trying to feel cool? Ok, you are “cool”. Although I would feel you were cooler if you could actually answer the question. Constantly being incorrect is not the brag you think it is.
Whatever you may interprete as angry may also be plain direct…instead of asking you can read the docs and the issues. Just start counting some of the questions and how often they re-appear then you might understand some of (my) comments
simple: I have a sensor that calculates the monthly costs. And I like to show this sensor on a monthly base in a bar chart, so that I can see, what I have used in Jan, Feb and so. Works, but the lables are wrong. That is my issue.
I guess the only chance will be to use the max option and then only 1 value for a month will be shown.
If you have issues or want a simple safe and reusable records of the data I suggest to use a monthly helper input number and an automation.
Every day on 23:59 the automation will write the most recent value into the monthly input number .
This way you get an update of the value every midnight of the increasing value. At the end of the month the highest value will show the consumption.
You can also do it only once a month but I prefer it daily. And then graphs are much easier to show.
I usually do it for the average daily consumption per month which will change vor a month and this way I get the daily figures saved.
