ApexCharts-card stacked bar graph doesn't stack when 'yaxis' is included
Greetings! I’m a long-time lurker, first-time poster. Thank you for all the help everyone has provided to me over the years.
I hit upon something this morning that has me stumped and I haven’t found the solution in any of the existing posts.
When I omit ‘yaxis’ from the ApexCharts Card Configuration, I get the stacked bar graph I want (except that the yaxis isn’t formatted as desired):
But when I include ‘yaxis’, the graph is no longer stacked:
Am I missing something obvious?
Thank you so much,
Matt
I have seen this happen for quite some time but only took time to figure out why today.
I found that since 2.1.0, one needs to assign column series to stack_groups if yaxis is present.
Reported upstream as Column charts do not stack without stack_group if yaxis is set · Issue #827 · RomRider/apexcharts-card · GitHub
Thank you, @scop. I would not have figured that one out on my own.
Here’s my final code:
