I designed a Dashboard containing several ApexCharts, all with dynamic x-axis (from sunrise to sunset), why I had to use card-templater.
Finally everything works fine, data is being displayed as desired, but the chart is refreshing nearly every second. Ok, seven inverters push data to HomeAssistant and make it quite busy with frequently updating inverter power values. So I tried to use “update_interval” and set it to 30 seconds. No change, no matter where I tried and no matter how often I put the parameter in the code. Could find some example, but in my case, it didn’t work. Probably because it is used “inside” the card-templater?
type: custom:card-templater
card:
type: custom:apexcharts-card
apex_config:
update_interval: 30sec
yaxis:
- id: first
forceNiceScale: true
decimalsInFloat: 0
legend:
show: true
showForZeroSeries: true
position: top
horizontalAlign: left
floating: false
fontSize: 9px
graph_span_template: "{{ states('input_text.graph_span_heute') }}"
span:
start: day
offset_template: +{{ states('input_text.offset') }}
all_series_config:
curve: smooth
type: line
opacity: 1
stroke_width: 1
float_precision: 0
group_by:
func: avg
duration: 10min
header:
show: true
title: PV-Auslastung alle
show_states: false
colorize_states: true
series:
- entity: sensor.prozent_hoege6alt_pv_leistung
color: orange
stroke_width: 1
extend_to: false
float_precision: 0
- entity: sensor.prozent_sensor_gen24_pv_leistung
color: blue
curve: smooth
type: line
extend_to: false
float_precision: 0
- entity: sensor.prozent_sensor_solax_sxuqbjt8wj_gelander_24kwp_ac_power
color: magenta
curve: smooth
type: line
extend_to: false
float_precision: 0
- entity: sensor.prozent_solax_sxm6ccalpa_fassade_12_kwp_ac_power
color: white
curve: smooth
type: line
stroke_width: 1
extend_to: false
- entity: sensor.prozent_solax_sxmygywxqj_fassade_05_kwp_ac_power
color: red
curve: smooth
type: line
extend_to: false
- entity: sensor.prozent_kaco_inverter_watts
color: red
curve: smooth
type: line
extend_to: false
- entity: sensor.prozent_symo_4_5_3_m_1_leistung_ac
color: black
curve: smooth
type: line
extend_to: false
entities:
- entity: sensor.prozent_gen24_pv_leistung
- entity: sensor.prozent_solax_sxuqbjt8wj_gelander_24kwp_ac_power
Can anybody give me a hint, how to use “update_interval” in combination with card-templater? Or any better ideas…?
Thanks in advance…
