ApexCharts xaxis Formatting Issues
Hey there, trying to understand ApexCharts formatting. I have weird issue I can’t seem to solve where setting my series period to “day” reduces the amount of days shown on the chart. As you can see, graph_span is set to 28d, why isn’t the chart spreading everything out to show the full 28 days?
Here is the code:
type: custom:apexcharts-card
graph_span: 28d
span:
  start: day
apex_config:
  grid:
    show: true
    strokeDashArray: 0
    borderColor: grey
  chart:
    height: 200
  xaxis:
    labels:
      format: dd
      show: true
      rotate: 0
      rotateAlways: false
yaxis:
  - decimals: 0
    show: true
    min: 0
    max: ~5
all_series_config:
  stroke_width: 1
header:
  show: true
  title: Daily Operations
  show_states: false
  colorize_states: true
series:
  - entity: sensor.sump_pump_1_daily
    type: column
    opacity: 0.5
    name: Pump 1 (Primary)
    statistics:
      type: max
      period: day
      align: middle
  - entity: sensor.sump_pump_2_daily
    type: column
    opacity: 0.5
    name: Pump 2 (Backup)
    statistics:
      type: max
      period: day
      align: middle
If I remove the “period: day” from the entity statistic option, the chart plots the full 28 days across the span of the chart, however it will now plot with the default 5 minute periods, which is not what I want. I’m simply looking for the total value of the sensor each day.
Thanks.
