API connection issues with ESPHome and Tianpower BMS (ESP32)
Hello everyone,
I am trying to integrate a Tianpower Battery Management System (BMS) with ESPHome using the external component from syssi/esphome-tianpower-bms.
Current configuration
substitutions:
  external_components_source: github://syssi/esphome-tianpower-bms@main
  mac_address: 2C:C6:82:77:40:5C
esphome:
  friendly_name: Esp32 Basen
  min_version: 2025.10.3
  project:
    version: 2.0.0
esp32:
  board: esp32dev
  framework:
    type: arduino
external_components:
  - source: ${external_components_source}
    refresh: 0s
logger:
  level: VERY_VERBOSE
api:
  reboot_timeout: 0s
ota:
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
esp32_ble_tracker:
ble_client:
  - mac_address: ${mac_address}
tianpower_bms_ble:
  - ble_client_id: client0
    update_interval: 10s
  • The ESP connects correctly to Wi‑Fi and responds via OTA.
  • The api: section is enabled without encryption (reboot_timeout: 0s).
  • Port 6053 does not respond: Home Assistant cannot connect via API.
  • Serial logs show no obvious errors, but it seems the firmware enters safe mode or BLE prevents the API from starting.
  • With a minimal firmware (Wi‑Fi + API + OTA only), port 6053 opens normally, so the issue appears related to the BLE/Tianpower component.
