Hi all,
I’m on a RPi4, core-2021.10.5, using ZWave_JS, Driver Version: 8.4.1
Server Version: 1.10.7, with a SI ZST10-700 controller.
I’m getting an API error when I try to set Parameter 16 on an Inovelli Red Series Dimmer (LZW31-SN
, v1.57).
I am attempting to use the LED notification to tell me when the alarm is armed. Using SERVICE ZWAVE_JS.SET_CONFIG_PARAMETER in either an automation or NodeRed gives me the same error, though, when it’s triggered:
"Call-service error. Configuration parameter with value ID 4-112-0-16 could not be found"
Here’s the JSON I’m using. I calculated the value using Inovelli Switch Toolbox.
{"parameter":"16", "value":"33491456"}
Manually updating the parameter 16 values that are available in the device configuration works, however.
What did I do wrong?!
