Hi all,
This is driving me insane and I’ve finally admitted defeat.
I have this (messy) flow, which turns off two local radiators when the rear door is open for more than 15 seconds and if it is open for more than 5 minutes it turns off all of the heating downstairs:
It works, the scenes are created automatically and the radiators/'stat are turned on or off, irrespective of whether the API error is showing for the first scene (the local rads) or not. If the door is open >15s but <5m the first scene call service node will show that it has been successfully called, as it should, >5m and it shows that an API error has occurred. Debug shows:
21/04/2021, 07:00:43 node: Turn on scene
msg : string[103]
Call-service API error. Error Message: string value is None for dictionary value @ data['preset_mode']
I also end up with the following in my HA log:
Logger: homeassistant.core
Source: core.py:1434
First occurred: 7:01:01 (1 occurrences)
Last logged: 7:01:01
Error executing service: <ServiceCall scene.turn_on (c:282a072f532dd91fd1d44609b4a4f789): entity_id=['scene.rear_door_extended_snapshot']>
File "/usr/src/homeassistant/homeassistant/core.py", line 1496, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1515, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 206, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 649, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 692, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 686, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 313, in async_activate
await async_reproduce_state(
File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 115, in async_reproduce_state
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 109, in worker
await platform.async_reproduce_states( # type: ignore
File "/usr/src/homeassistant/homeassistant/components/climate/reproduce_state.py", line 84, in async_reproduce_states
File "/usr/src/homeassistant/homeassistant/components/climate/reproduce_state.py", line 67, in _async_reproduce_states
await call_service(SERVICE_SET_PRESET_MODE, [ATTR_PRESET_MODE])
File "/usr/src/homeassistant/homeassistant/components/climate/reproduce_state.py", line 46, in call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1434, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 341, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 337, in _exec
v = func(v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: string value is None for dictionary value @ data['preset_mode']
Can anyone tell me what is causing this and how I can fix whatever I’ve done wrong please?
Exported flow:
[{"id":"b0242f35.84c88","type":"tab","label":"Heating","disabled":false,"info":""},{"id":"7476ca0e.ae2a34","type":"comment","z":"b0242f35.84c88","name":"Rear door opened, wait 15 seconds; turn rear door/washroom radiators off. If door is still open after 5 minutes, turn off heating downstairs. Reset to previous states when door closed","info":"","x":610,"y":40,"wires":[]},{"id":"b123daa6.9b8338","type":"server-state-changed","z":"b0242f35.84c88","name":"Rear door open?","server":"","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.rear_door_contact_sensor_contact","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":100,"y":200,"wires":[["1b9f54ed.73425b","216e0f53.33a7e"],["712fa4df.1bfa8c","a879d3aa.73f91","b8f58910.0a6998","3845932f.8d754c"]]},{"id":"1b9f54ed.73425b","type":"api-call-service","z":"b0242f35.84c88","name":"Create scene","server":"","version":1,"debugenabled":false,"service_domain":"scene","service":"create","entityId":"","data":"{\"scene_id\":\"rear_door_snapshot\",\"snapshot_entities\":[\"climate.washroom_radiator\",\"climate.rear_door_radiator\"]}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":270,"y":100,"wires":[["712fa4df.1bfa8c"]]},{"id":"229ed6f5.58eeda","type":"api-call-service","z":"b0242f35.84c88","name":"Turn radiators off","server":"","version":1,"debugenabled":false,"service_domain":"climate","service":"turn_off","entityId":"{{payload.entity_id}}","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":890,"y":100,"wires":[[]]},{"id":"712fa4df.1bfa8c","type":"trigger","z":"b0242f35.84c88","name":"","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"off","bytopic":"all","topic":"topic","outputs":1,"x":490,"y":100,"wires":[["9a0e6939.a17568"]]},{"id":"9a0e6939.a17568","type":"ha-get-entities","z":"b0242f35.84c88","server":"","name":"Find rads that aren't off","rules":[{"property":"entity_id","logic":"includes","value":"climate.washroom_radiator, climate.rear_door_radiator","valueType":"str"},{"property":"state","logic":"is_not","value":"off","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":680,"y":100,"wires":[["229ed6f5.58eeda"]]},{"id":"216e0f53.33a7e","type":"api-call-service","z":"b0242f35.84c88","name":"Create scene","server":"","version":1,"debugenabled":false,"service_domain":"scene","service":"create","entityId":"","data":"{\"scene_id\":\"rear_door_extended_snapshot\",\"snapshot_entities\":[\"climate.downstairs\"]}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":270,"y":160,"wires":[["b8f58910.0a6998"]]},{"id":"b8f58910.0a6998","type":"trigger","z":"b0242f35.84c88","name":"","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"min","reset":"off","bytopic":"all","topic":"topic","outputs":1,"x":490,"y":160,"wires":[["82f15b5d.43cab8"]]},{"id":"929b9999.c0a458","type":"api-call-service","z":"b0242f35.84c88","name":"Turn radiators off","server":"","version":1,"debugenabled":false,"service_domain":"climate","service":"turn_off","entityId":"{{payload.entity_id}}","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":890,"y":160,"wires":[[]]},{"id":"82f15b5d.43cab8","type":"ha-get-entities","z":"b0242f35.84c88","server":"","name":"Find rads that aren't off","rules":[{"property":"entity_id","logic":"includes","value":"climate.downstairs","valueType":"str"},{"property":"state","logic":"is_not","value":"off","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":680,"y":160,"wires":[["929b9999.c0a458"]]},{"id":"ae4cfe5e.775ca","type":"api-call-service","z":"b0242f35.84c88","name":"Turn on scene","server":"","version":1,"debugenabled":false,"service_domain":"scene","service":"turn_on","entityId":"scene.rear_door_extended_snapshot","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":480,"y":280,"wires":[[]]},{"id":"a879d3aa.73f91","type":"api-current-state","z":"b0242f35.84c88","name":"Is downstairs off?","server":"","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"climate.downstairs","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":290,"y":280,"wires":[["ae4cfe5e.775ca"],[]]},{"id":"3845932f.8d754c","type":"api-call-service","z":"b0242f35.84c88","name":"Turn on scene","server":"","version":1,"debugenabled":false,"service_domain":"scene","service":"turn_on","entityId":"scene.rear_door_snapshot","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":280,"y":220,"wires":[["573e68ba.510ea8"]]},{"id":"573e68ba.510ea8","type":"debug","z":"b0242f35.84c88","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":430,"y":220,"wires":[]}]
Also, if anyone has any suggestions on how to improve or clean up this mess please go ahead!
Thanks.
