Hi guys, can anyone help here. Bit out of my depth.
Trying to update a few Apollo MSR-1 devices from 2025.7.5 in ESPHome.
I click on validate, all fine but when I click on upload and then wireless I get the following error.
INFO ESPHome 2025.8.1
INFO Reading configuration /config/esphome/apollo-msr-1-dbc32c.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing apollo-msr-1-dbc32c (board: esp32-c3-devkitm-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip)
INFO Package configuration completed successfully
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.50402.0 (5.4.2)
- tool-cmake @ 3.30.2
- tool-esp-rom-elfs @ 2024.10.11
- tool-esptoolpy @ 5.0.2
- tool-mklittlefs @ 3.2.0
- tool-ninja @ 1.13.1
- tool-scons @ 4.40801.0 (4.8.1)
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-riscv32-esp @ 14.2.0+20241119
Reading CMake configuration...
-- git rev-parse returned 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Found assembler: riscv32-esp-elf-gcc
-- Warning: Did not find file Compiler/-ASM
-- Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:571 (__project):
The CMAKE_C_COMPILER:
riscv32-esp-elf-gcc
is not a full path and was not found in the PATH.
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
Call Stack (most recent call first):
CMakeLists.txt:3 (project)
The CMAKE_CXX_COMPILER:
riscv32-esp-elf-g++
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
The CMAKE_ASM_COMPILER:
riscv32-esp-elf-gcc
variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
========================= [FAILED] Took 11.89 seconds =========================
