Every time I get so far down the sensor menu the app crashes and restarts, if in the android auto settings as soon as I select an item the app crashes and restarts. In all other ways app seems fine. Tried clearing the cache and data and then uninstalled and reinstalled, no different.
Timestamp: 2025-05-13 17:24:55.612
Thread: main
Exception: java.lang.NoSuchMethodError
at kotlin.UByte$$ExternalSyntheticBackport0.m(D8$$SyntheticClass:0)
at org.burnoutcrew.reorderable.ReorderableItemKt.ReorderableItem(ReorderableItem.kt:37)
at io.homeassistant.companion.android.settings.vehicle.views.AndroidAutoFavoritesViewKt$AndroidAutoFavoritesSettings$2$1$4.invoke(AndroidAutoFavoritesView.kt:108)
at io.homeassistant.companion.android.settings.vehicle.views.AndroidAutoFavoritesViewKt$AndroidAutoFavoritesSettings$2$1$4.invoke(AndroidAutoFavoritesView.kt:104)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.kt:142)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.kt:51)
at androidx.compose.foundation.lazy.LazyListItemProviderImpl$Item$1.invoke(LazyListItemProvider.kt:84)
at androidx.compose.foundation.lazy.LazyListItemProviderImpl$Item$1.invoke(LazyListItemProvider.kt:82)
at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.kt:121)
at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:384)
at androidx.compose.foundation.lazy.layout.LazyLayoutPinnableItemKt.LazyLayoutPinnableItem(LazyLayoutPinnableItem.kt:56)
at androidx.compose.foundation.lazy.LazyListItemProviderImpl.Item(LazyListItemProvider.kt:82)
at androidx.compose.foundation.lazy.layout.LazyLayoutItemContentFactoryKt$SkippableItem$1.invoke(LazyLayoutItemContentFactory.kt:130)
at androidx.compose.foundation.lazy.layout.LazyLayoutItemContentFactoryKt$SkippableItem$1.invoke(LazyLayoutItemContentFactory.kt:129)
at androidx.compose.runtime.saveable.SaveableStateHolderImpl.SaveableStateProvider(SaveableStateHolder.kt:79)
at androidx.compose.foundation.lazy.layout.LazySaveableStateHolder.SaveableStateProvider(LazySaveableStateHolder.kt:76)
at androidx.compose.foundation.lazy.layout.LazyLayoutItemContentFactoryKt.SkippableItem-JVlU9Rs(LazyLayoutItemContentFactory.kt:129)
at androidx.compose.foundation.lazy.layout.LazyLayoutItemContentFactoryKt.access$SkippableItem-JVlU9Rs(LazyLayoutItemContentFactory.kt:1)
at androidx.compose.foundation.lazy.layout.LazyLayoutItemContentFactory$CachedItemContent$createContentLambda$1.invoke(LazyLayoutItemContentFactory.kt:97)
at androidx.compose.foundation.lazy.layout.LazyLayoutItemContentFactory$CachedItemContent$createContentLambda$1.invoke(LazyLayoutItemContentFactory.kt:87)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$subcompose$3$1$1.invoke(SubcomposeLayout.kt:1042)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$subcompose$3$1$1.invoke(SubcomposeLayout.kt:523)
at androidx.compose.runtime.internal.Utils_jvmKt.invokeComposable(Utils.jvm.kt:27)
at androidx.compose.runtime.ComposerImpl.doCompose-aFTiNEg(Composer.kt:3694)
at androidx.compose.runtime.ComposerImpl.composeContentāZbOJvo$runtime_release(Composer.kt:3616)
at androidx.compose.runtime.CompositionImpl.composeContent(Composition.kt:792)
at androidx.compose.runtime.Recomposer.composeInitial$runtime_release(Recomposer.kt:1132)
at androidx.compose.runtime.ComposerImpl$CompositionContextImpl.composeInitial$runtime_release(Composer.kt:4034)
at androidx.compose.runtime.CompositionImpl.composeInitial(Composition.kt:677)
at androidx.compose.runtime.CompositionImpl.setContent(Composition.kt:616)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcomposeInto(SubcomposeLayout.kt:544)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcompose(SubcomposeLayout.kt:514)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcompose(SubcomposeLayout.kt:504)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcompose(SubcomposeLayout.kt:490)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$Scope.subcompose(SubcomposeLayout.kt:926)
at androidx.compose.foundation.lazy.layout.LazyLayoutMeasureScopeImpl.measure-0kLqBqw(LazyLayoutMeasureScope.kt:124)
at androidx.compose.foundation.lazy.LazyListMeasuredItemProvider.getAndMeasure-0kLqBqw(LazyListMeasuredItemProvider.kt:55)
at androidx.compose.foundation.lazy.LazyListMeasuredItemProvider.getAndMeasure-0kLqBqw$default(LazyListMeasuredItemProvider.kt:49)
at androidx.compose.foundation.lazy.LazyListMeasureKt.measureLazyList-LCrQqZ4(LazyListMeasure.kt:222)
at androidx.compose.foundation.lazy.LazyListKt$rememberLazyListMeasurePolicy$1$1.invoke-0kLqBqw(LazyList.kt:352)
at androidx.compose.foundation.lazy.LazyListKt$rememberLazyListMeasurePolicy$1$1.invoke(LazyList.kt:200)
at androidx.compose.foundation.lazy.layout.LazyLayoutKt$LazyLayout$1$2$1.invoke-0kLqBqw(LazyLayout.kt:78)
at androidx.compose.foundation.lazy.layout.LazyLayoutKt$LazyLayout$1$2$1.invoke(LazyLayout.kt:76)
at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$createMeasurePolicy$1.measure-3p2s80s(SubcomposeLayout.kt:754)
at androidx.compose.ui.node.InnerNodeCoordinator.measure-BRTryo0(InnerNodeCoordinator.kt:128)
at androidx.compose.ui.graphics.SimpleGraphicsLayerModifier.measure-3p2s80s(GraphicsLayerModifier.kt:642)
at androidx.compose.ui.node.LayoutModifierNodeCoordinator.measure-BRTryo0(LayoutModifierNodeCoordinator.kt:190)
at androidx.compose.foundation.lazy.layout.LazyLayoutBeyondBoundsModifierNode.measure-3p2s80s(LazyLayoutBeyondBoundsModifierLocal.kt:118)
at androidx.compose.ui.node.MeasurePassDelegate$performMeasureBlock$1.invoke(MeasurePassDelegate.kt:169)
at androidx.compose.ui.node.MeasurePassDelegate$performMeasureBlock$1.invoke(MeasurePassDelegate.kt:168)
at androidx.compose.runtime.snapshots.Snapshot$Companion.observe(Snapshot.kt:501)
at androidx.compose.runtime.snapshots.SnapshotStateObserver$ObservedScopeMap.observe(SnapshotStateObserver.kt:460)
at androidx.compose.runtime.snapshots.SnapshotStateObserver.observeReads(SnapshotStateObserver.kt:244)
at androidx.compose.ui.node.OwnerSnapshotObserver.observeReads$ui_release(OwnerSnapshotObserver.kt:124)
at androidx.compose.ui.node.OwnerSnapshotObserver.observeMeasureSnapshotReads$ui_release(OwnerSnapshotObserver.kt:107)
at androidx.compose.ui.node.MeasurePassDelegate.performMeasure-BRTryo0$ui_release(MeasurePassDelegate.kt:422)
at androidx.compose.ui.node.MeasurePassDelegate.remeasure-BRTryo0(MeasurePassDelegate.kt:470)
at androidx.compose.ui.node.MeasurePassDelegate.measure-BRTryo0(MeasurePassDelegate.kt:450)
at androidx.compose.ui.layout.RootMeasurePolicy.measure-3p2s80s(RootMeasurePolicy.kt:37)
at androidx.compose.runtime.snapshots.Snapshot$Companion.observe(Snapshot.kt:2496)
at androidx.compose.ui.node.LayoutNode.remeasure-_Sx5XlM$ui_release(LayoutNode.kt:1212)
at androidx.compose.ui.node.MeasureAndLayoutDelegate.doRemeasure-sdFAvZA(MeasureAndLayoutDelegate.kt:364)
at androidx.compose.ui.node.MeasureAndLayoutDelegate.remeasureOnly(MeasureAndLayoutDelegate.kt:629)
at androidx.compose.ui.node.MeasureAndLayoutDelegate.measureOnly(MeasureAndLayoutDelegate.kt:419)
at androidx.compose.ui.platform.AndroidComposeView.onMeasure(AndroidComposeView.android.kt:1649)
at android.view.View.layout(View.java:25465)
at android.view.ViewGroup.layout(ViewGroup.java:6441)
at androidx.compose.ui.platform.AbstractComposeView.internalOnLayout$ui_release(ComposeView.android.kt:320)
at androidx.compose.ui.platform.AbstractComposeView.onLayout(ComposeView.android.kt:310)
at android.view.View.layout(View.java:25484)
at android.widget.FrameLayout.layoutChildren(FrameLayout.java:332)
at android.widget.FrameLayout.onLayout(FrameLayout.java:270)
at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1891)
at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1729)
at android.widget.LinearLayout.onLayout(LinearLayout.java:1638)
at android.widget.RelativeLayout.onLayout(RelativeLayout.java:1103)
at com.android.internal.policy.DecorView.onLayout(DecorView.java:779)
at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:5214)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:4329)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:3155)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:10833)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1406)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1415)
at android.view.Choreographer.doCallbacks(Choreographer.java:1015)
at android.view.Choreographer.doFrame(Choreographer.java:945)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:1389)
at android.os.Handler.handleCallback(Handler.java:1001)
at android.os.Handler.dispatchMessage(Handler.java:105)
at android.os.Looper.loopOnce(Looper.java:268)
at android.os.Looper.loop(Looper.java:384)
at android.app.ActivityThread.main(ActivityThread.java:8921)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:580)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:907)
