Is it possible to create an automation that when an app fails to load (in my case z2m sometimes fails to load) to them notify me?
Even better can I trigger that automation to try to reload that app?
The Home Assistant Supervisor integration is what you’re looking for. You’ll have to enable the binary_sensor ‘Running’ and then you can test if its running in a template trigger
automation:
triggers:
- trigger: template
value_template: "{{ is_state('binary_sensor.your_app_running', 'on') }}"
You can then start it with
action: hassio.app_start
app: your_app
As for notifying you, that would depend on how you want to be notified.
