evmqtt-rs turns keyboard key presses into MQTT messages, because sometimes
a simple keyboard is the best remote control for your smart home.
It is similar to the native keyboard_remote integration, but supports configuration
from UI, creates devices with readable trigger names, and can run on a different
machine communicating with Home Assistant via MQTT.
I am running it on Raspberry Pi Zero 2 W to use Satechi Slim Alu Keypad as a remote,
and decided to publish and package it as a Home Assistant App now.
Highlights
- No static device list — every connected device with buttons is auto-detected
and announced to Home Assistant on first sighting. - Each detected device shows up in HA with an Enabled switch. Flip it on
andevmqtt-rsstarts grabbing events from that device; flip it off and
the device returns to the kernel. State survives restarts. and disconnects. - Triggers are added to HA per-key, lazily — the first time you press a key
on an enabled device, that key's*_press/*_releasetriggers appear
in HA, ready to use in automations.
Instructions
Add repository https://github.com/bdolgov/evmqtt-rs, install evmqtt-rs,
and start it.
Every detected device gets:
- An Enabled switch component, wired to the daemon's enable/disable
control topic. Flipping the switch in HA enables or disables monitoring
for that device. - One MQTT Device Trigger pair (
*_pressand*_release) for every key
the daemon has ever observed on that device. The discovery payload is
re-published whenever a new key arrives.
Triggers only appear after a key has been pressed at least once with the
device enabled. If you want them pre-populated, press each key once with
HA's MQTT integration listening — the discovery message is retained.
More Information
For more information (standalone installation not on HAOS, topic structure, FAQ),
see the README in the repo linked above.
