[App] GARDENA smart Gateway → local, cloud-free Matter & MQTT bridge
I built a Home Assistant add-on that turns the GARDENA smart Gateway (Art. 19005) into a standalone Matter device — the Matter stack runs directly on the gateway, so your GARDENA devices show up locally in Home Assistant (or any Matter fabric) without the GARDENA cloud and without a second server. Optionally it also publishes every sensor value over MQTT (HA MQTT discovery), so you get your devices two ways.
Install is a normal add-on flow — no SSH, no building, no flashing: add the repository, install, enter the device ID from the sticker, deploy. It installs into the gateway's writable overlay and is reversible (uninstall scripts included).
Honest status: this is a private hobby project, not affiliated with GARDENA/Husqvarna, use at your own risk. I can only verify it against the hardware I own — smart soil sensors + one SILENO mower. Everything else (Water Control / valves, pressure pump, smart power plug, other sensors/mowers) is modelled in code but not yet tested on real hardware. Apple Home / Google Home are untested.
What I'm looking for: testers — especially anyone with other GARDENA devices. The single most useful thing is data I can map a device from: the bridge's own log + a redacted snapshot of the device data layer (/var/lib/lemonbeatd/). The repo's Contributing page explains exactly what to capture and how to redact it. Bug reports and "it works / it doesn't" feedback are very welcome too.
:link: Repo + one-click install: GitHub - wuselAUT/gardena-matter-mqtt-bridge: Cloud-free Matter & MQTT bridge for the GARDENA smart Gateway (19005) — runs on the gateway, no cloud. Home Assistant add-on. · GitHub :open_book: Docs (EN/DE, with a language switcher): GARDENA Matter Bridge
BR wusel :seedling:
They're not called add-ons any more.
Your release (e.g. gardena-bridge-v0.1.7.tar.gz) contains binaries (chip-bridge-app.stripped, matter_libs.tar.gz) for which there is no source code available. Can you please add the sources and instructions for building the binaries running on the gateway?
Until then, I’d rather not execute this code on a GARDENA smart gateway.
