Unfortunately AppDaemon 4 version 0.3.0 does not show icon after the update (I was previliously on 0.2.x)
Mydash.dash
## Main arguments, all optional
title: Main Panel
widget_dimensions: [110, 110]
widget_size: [1, 1]
widget_margins: [5, 5]
columns: 8
global_parameters:
use_comma: 0
precision: 1
use_hass_icon: 1
namespace: default
devices:
media_player:
step: 5
clock:
widget_type: clock
widget_style: "font-size: 110%;"
time_style: "color: yellow;"
date_style: "color: yellow;"
time_format: 24hr
vacuum:
widget_type: vacuum
entity: vacuum.xiaomi_vacuum_cleaner
title: My vacuum cleaner
layout:
- vacuum(3x2)
# vacuum_widget_style: $background_style
# vacuum_title_style: $style_title
door_chime:
widget_type: switch
title: Dining Light automation
icon_on: mdi-lightbulb
icon_off: mdi-lightbulb
entity: automation.turn_off_dining_room_light_3_minutes_after_last_movement
my_camera:
widget_type: camerastream
entity: camera.roborock_s50
title: Roborock S50
base_url: "https://xxx.duckdns.org"
log: 1 # optional. Will print some log info in the console for debugging purposes if set to 1.
layout:
- my_camera(2x2)
pic:
widget_type: iframe
refresh: 10
url_list:
- http://xxx.xxx.xxx.xxx:xxxx/api/map/image
layout:
- pic(3x3)
your_input_select:
widget_type: input_select
entity: input_select.vacuum_input
layout:
- weather.dark_sky (2x2), sensor.temperature_158d0001fa6c8f, sensor.temperature_158d0001fa7039, sensor.temperature_158d0002c9cb5c, clock(2x1), sensor.wallpanel_battery_level
- vacuum.xiaomi_vacuum_cleaner(3x2), my_camera(2x2), light.living_room_light
- device_tracker.1_iphone, person.1, light.gateway_light_7811dcb794df
- script.kitchen, script.diningkitchen, script.dinkithall, script.dining, script.bed, script.living, door_chime, light.dining_room_light
- binary_sensor.door_window_sensor_158d00019f51d7, binary_sensor.door_window_sensor_158d00019fdc00, binary_sensor.door_window_sensor_158d0001ab6f8c, binary_sensor.door_window_sensor_158d0001dcb034, binary_sensor.door_window_sensor_158d0002b6e9d7, binary_sensor.door_window_sensor_158d0002c6fc75, binary_sensor.door_window_sensor_158d0002c6fcad, input_select.vacuum_input
appdaemon.yaml
secrets: /config/secrets.yaml
appdaemon:
time_zone: Europe/Amsterdam
plugins:
HASS:
type: hass
http:
url: http://xxx.xxx.xxx.xxx:xxxxxx
admin:
api:
hadashboard:
Could you help me what should I modify?
