Hi, i’ve updated AppDaemon in my HassIO installation to 5.0.0, and since then it fails to start if I include the python-telegram-bot package, even if the app that uses the package is not loaded.
Anyone else is facing the same issue?
This is the error logged
Collecting future>=0.16.0 (from python-telegram-bot)
Downloading https://wheels.hass.io/alpine-3.10/armv7/future-0.18.2-py3-none-any.whl (491kB)
Collecting cryptography (from python-telegram-bot)
Downloading https://files.pythonhosted.org/packages/be/60/da377e1bed002716fb2d5d1d1cab720f298cb33ecff7bf7adea72788e4e4/cryptography-2.8.tar.gz (504kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'error'
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3.8 /usr/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-fd3j6qxn/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --find-links https://wheels.hass.io/alpine-3.10/armv7/ -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"''
cwd: None
Complete output (68 lines):
Looking in links: https://wheels.hass.io/alpine-3.10/armv7/
Collecting setuptools>=40.6.0
Using cached https://files.pythonhosted.org/packages/f9/d3/955738b20d3832dfa3cd3d9b07e29a8162edb480bf988332f5e6e48ca444/setuptools-44.0.0-py2.py3-none-any.whl
Collecting wheel
Using cached https://files.pythonhosted.org/packages/00/83/b4a77d044e78ad1a45610eb88f745be2fd2c6d658f9798a15e384b7d57c9/wheel-0.33.6-py2.py3-none-any.whl
Collecting cffi!=1.11.3,>=1.8
Using cached https://files.pythonhosted.org/packages/2d/bf/960e5a422db3ac1a5e612cb35ca436c3fc985ed4b7ed13a1b4879006f450/cffi-1.13.2.tar.gz
Collecting pycparser (from cffi!=1.11.3,>=1.8)
Downloading https://wheels.hass.io/alpine-3.10/armv7/pycparser-2.19-py2.py3-none-any.whl (111kB)
Installing collected packages: setuptools, wheel, pycparser, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
command: /usr/bin/python3.8 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-3o2t099g/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-3o2t099g/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-7brlcm5v/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-fd3j6qxn/overlay --compile
cwd: /tmp/pip-install-3o2t099g/cffi/
Complete output (48 lines):
unable to execute 'gcc': No such file or directory
No working compiler found, or bogus compiler options passed to
the compiler from Python's standard "distutils" module. See
the error messages above. Likely, the problem is not related
to CFFI but generic to the setup.py of any Python package that
tries to compile C code. (Hints: on OS/X 10.8, for errors about
-mno-fused-madd see http://stackoverflow.com/questions/22313407/
Otherwise, see https://wiki.python.org/moin/CompLangPython or
the IRC channel #python on irc.freenode.net.)
Trying to continue anyway. If you are trying to install CFFI from
a build done in a different context, you can ignore this warning.
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.8
creating build/lib.linux-armv7l-3.8/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/recompiler.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/__init__.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/model.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/verifier.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/error.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/api.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/cparser.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/commontypes.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/lock.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_embedding.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.8/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-armv7l-3.8
creating build/temp.linux-armv7l-3.8/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Os -fomit-frame-pointer -g -Os -fomit-frame-pointer -g -Os -fomit-frame-pointer -g -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.8 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.8/c/_cffi_backend.o
error: command 'gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /usr/bin/python3.8 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-3o2t099g/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-3o2t099g/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-7brlcm5v/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-fd3j6qxn/overlay --compile Check the logs for full command output.
WARNING: You are using pip version 19.2.3, however version 19.3.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
ERROR: Command errored out with exit status 1: /usr/bin/python3.8 /usr/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-fd3j6qxn/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --find-links https://wheels.hass.io/alpine-3.10/armv7/ -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
[10:07:21] FATAL: Failed installing package python-telegram-bot
[cont-init.d] appdaemon.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] appdaemon.sh: executing...
[cont-finish.d] appdaemon.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
