AppDaemon dashboard not accessible after installing NGINX add-on
The AppDaemon dashboard is not accessible after installing NGINX add-on. I have forward the port 443 to 443 inside router and I can access the HA and the Configurator from inside and outside of network but unfortunately something went wrong with the AppDaemon settings.
Here is the AppDaemon log.
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: AppDaemon
 Python Apps and HADashboard using AppDaemon 3.x for Home Assistant
 Add-on version: 2.0.2
 You are running the latest version of this add-on.
 System: HassOS 1.13  (aarch64 / raspberrypi3-64)
 Home Assistant version: 0.86.4
 Supervisor version: 152
 Please, share the above information when looking for help
 or support in e.g, GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 20-init-configuration.sh: executing...
[cont-init.d] 20-init-configuration.sh: exited 0.
[cont-init.d] 21-compiled-dir.sh: executing...
[cont-init.d] 21-compiled-dir.sh: exited 0.
[cont-init.d] 30-auto-token.sh: executing...
[00:53:19] INFO: Updating Hass.io API token in AppDaemon with the current one...
[cont-init.d] 30-auto-token.sh: exited 0.
[cont-init.d] 31-ha-url.sh: executing...
[cont-init.d] 31-ha-url.sh: exited 0.
[cont-init.d] 50-compiled-symlink.sh: executing...
[cont-init.d] 50-compiled-symlink.sh: exited 0.
[cont-init.d] 80-system-packages.sh: executing...
[cont-init.d] 80-system-packages.sh: exited 0.
[cont-init.d] 81-python-packages.sh: executing...
[cont-init.d] 81-python-packages.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[00:53:21] INFO: Starting AppDaemon...
[00:53:22] INFO: Starting AppDaemon...
[00:53:23] INFO: Starting AppDaemon...
[00:53:24] INFO: Starting AppDaemon...
[00:53:25] INFO: Starting AppDaemon...
[00:53:26] INFO: Starting AppDaemon...
[00:53:27] INFO: Starting AppDaemon...
[00:53:28] INFO: Starting AppDaemon...
[00:53:29] INFO: Starting AppDaemon...
[00:53:30] INFO: Starting AppDaemon...
[00:53:31] INFO: Starting AppDaemon...
Kindly help me to solve this problem.
Same problem here after updating appdaemon
same problem here. home assistant 0.91
So is there anyway to rollback to previous version?
Hi jmwick,
Since I haven’t got any solution for this issue and neither received any reply. I was wondering if you can please update in case you have any luck with it?
