Appdaemon schedule callback error
Is this the correct forum to ask about app daemon issue?
I am having some trouble with the scheduling. Please excuse my python, I only started learning it last week. So im trying to set modes for the house based on the time of day, below is a subset of the code im using. but I cant get the scheduler to work. Its just erroring with
2016-12-01 17:28:34.005890 WARNING Traceback (most recent call last):
  File "/usr/local/lib/python3.4/dist-packages/appdaemon/appdaemon.py", line 418, in worker
    function(ha.sanitize_timer_kwargs(args["kwargs"]))
TypeError: evening() takes 1 positional argument but 2 were given
import appdaemon.appapi as appapi
import datetime
class HouseMode(appapi.AppDaemon):
    def initialize(self):
        self.log('************* HouseMode Init *******************')
        self.mode = self.get_state("input_select.housemode")
        if self.sun_down():
            self.evening()
        #Setup triggers based on Time
        self.run_in(self.evening, seconds = 5)
    def evening(self):
        """Set the house up for evening"""
        if not self.mode == "Evening":
            self.mode = "Evening"
            self.log("Switching mode to Evening")
            self.select_option("input_select.housemode", "Evening")
        else:
            self.log('Already in Evening mode, not resetting mode')
Any help would be appreciated.
Hi there - you missed out a parameter in your callback, it should be:
 def evening(self, **kwargs):
thanks for the quick response. I have tried that, forgot to include the error.
Error
2016-12-01 18:14:54.012491 WARNING Traceback (most recent call last):
code
import datetime
        else:
            self.log('Already in Evening mode, not restting mode')
Your call to run_in() isn’t right - it should be:
self.run_in(self.evening, 5)
This still produces the same error.
2016-12-01 20:00:44.018598 WARNING Traceback (most recent call last):
import datetime
    def evening(self):
        else:
You still don;t have the kwargs argument, try this:
def evening(self, kwargs):
cool, so that works with the triggers. Would you mind showing me howto call evening outside the timer. So as part of initialize I have
        if self.sun_down():
            self.evening()
this works without kwargs in the def for evening
but once I put kwargs in I get
TypeError: evening() missing 1 required positional argument: 'kwargs'
(Thanks for your patience, and sorry my noob questions)
You could try using {} for the kwargs argument - it is expecting a dictionary and {} is an empty dictionary.
if self.sun_down():
            self.evening({})
Or maybe cleaner, have a 3rd procedure called do_evening() or something then call it from your evening() function as welll as directly.
THANK YOU! Ive been trying to understand what ive been doing wrong for a couple of days… both options work. (Im not completely sure why evening needs kwargs in the first place, but im not complaining as long as it works :slight_smile: )
Cheers again
It’s to allow you top pass parameters to your callbacks, but is entirely optional.
Thanks again. everything looks like its working correctly
House Mode Script
import datetime
        #Set mode on startup
        now = datetime.datetime.now().time()
        if now > datetime.time(23, 00) or now < datetime.time(5, 00):
            self.night({})
        elif self.sun_up():
            self.day({})
        elif self.sun_down():
            self.evening({})
        sun_offset = datetime.timedelta(minutes = 30).total_seconds()
        self.run_at_sunset(self.evening, offset = -sun_offset)
        self.run_at_sunrise(self.day, offset = sun_offset)
        self.run_daily(self.day, datetime.time(7, 00, 0))
    def day(self, kwargs):
        # Set the house up for daytime
        if not self.mode == "Day":
            self.mode = "Day"
            self.log("Switching mode to Day")
            self.select_option("input_select.housemode", "Day")
        else:
            self.log('Already in Day mode, not resetting mode')
        #Set the house up for evening
        else:
    def night(self, kwargs):
        #Set the hosue for nighttime
        if not self.mode == "Night":
            self.mode = "Night"
            self.log("Switching mode to Night")
            self.select_option("input_select.housemode", "Night")
            #Turn if all off
            #self.turn_off('group.all_lights')
        else:
            self.log('Already in Night mode, not resetting mode')
Cool - glad you figured it out :slight_smile:
