AppDaemon Version 3.0.0b5 giving me a hard time
Hi all
I’ve just updated my appdaemon as hadashboard on my iPad wasn’t responding to changes. Now appdaemon is refusing to play nice.
Here is the start and status message when it dies.
    pi@annabell:~ $ sudo systemctl start [email protected]
pi@annabell:~ $ sudo systemctl status [email protected][email protected] - AppDaemon service for Home Assistant
   Loaded: loaded (/etc/systemd/system/[email protected]; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2018-03-10 13:06:41 AEDT; 1s ago
  Process: 24512 ExecStart=/usr/local/bin/appdaemon -c /home/homeassistant/.homeassistant/apdconf (code=exited, status=1/FAILURE)
 Main PID: 24512 (code=exited, status=1/FAILURE)
Mar 10 13:06:41 annabell appdaemon[24512]:   File "/usr/local/lib/python3.5/dist-packages/appdaemon/admain.py", line 361, in main
Mar 10 13:06:41 annabell appdaemon[24512]:     self.run(appdaemon, hadashboard)
Mar 10 13:06:41 annabell appdaemon[24512]:   File "/usr/local/lib/python3.5/dist-packages/appdaemon/admain.py", line 60, in run
Mar 10 13:06:41 annabell appdaemon[24512]:     self.AD = ad.AppDaemon(self.logger, self.error, self.diag, loop, **appdaemon)
Mar 10 13:06:41 annabell appdaemon[24512]:   File "/usr/local/lib/python3.5/dist-packages/appdaemon/appdaemon.py", line 259, in __init__
Mar 10 13:06:41 annabell appdaemon[24512]:     basename = self.plugins[name]["type"]
Mar 10 13:06:41 annabell appdaemon[24512]: TypeError: string indices must be integers
Mar 10 13:06:41 annabell systemd[1]: [email protected]: Main process exited, code=exited, status=1/FAILURE
Mar 10 13:06:41 annabell systemd[1]: [email protected]: Unit entered failed state.
Mar 10 13:06:41 annabell systemd[1]: [email protected]: Failed with result 'exit-code'.
pi@annabell:~ $ AppDaemon Version 3.0.0b5^C
pi@annabell:~ $
The log entry
2018-03-10 13:06:41.070584 INFO AppDaemon Version 3.0.0b5 starting
2018-03-10 13:06:41.071354 INFO Configuration read from: /home/homeassistant/.homeassistant/apdconf/appdaemon.yaml
2018-03-10 13:06:41.073427 INFO AppDaemon: Starting Apps
and my appdaemon.yaml file.
    log:
      logfile: /home/homeassistant/logs/appdaemon.log
      errorfile: /home/homeassistant/logs/appdaemon.err
      accessfile: /home/homeassistant/logs/dash_access
      logsize: 100000
      log_generations: 3
    appdaemon:
      threads: 10
      api_port: 5000
      plugins:
        HASS:
        type: hass
        ha_url: http://localhost:8123
        namespace: default
    hadashboard:
      dash_url: http://localhost:5050
can anyone see what I’m missing please?
      plugins:
        HASS:
        type: hass
        namespace: default
should be
      plugins:
        HASS:
          type: hass
Thank you @ReneTode, that’s fixed it.
