Apple device switched on/ log on and it triggers certain devices to switch on without input
Hi, when I switch on iPhone, iPad or Mac which all have the HA app, the Denon Amp turns on without any input, automation to do so. I am relatively new to HA but how have found 'Denon Turned On' in the logs, but I cannot see why. Can anyone help with this issue pls?
If it just says the amp turned on, then it means HA does not know (ie. it did not originate from HA) why it turned on.
It just detected the amp as turning on.
OK, but it is always when I log onto a device that it triggers it. HA is the only device that controls the amp, TV, etc. If I unplug the HA, it doesn't happen. Any ideas?
No idea what makes it act like that.
When a device connects to HA it will get the state of the stored entities.
HA does not update the entities at exactly that time. It happens regular all the time.
