Apple Home shows not responding after power outage, need a permanent solutions
I have locks lights and other stuffs at home, connected via zigbee via mgtt via home assistant with apple home service.
once the power is off (outage) and back on 2 minutes late, when my ha is reboot, all the accesories became ‘Not Responding’ on Apple Home but homeassisstant shows normal.
I know reboot my HA again manually would solve this problem, it works all the time…
Is there a permanent solution for this? for example an automation to refresh all servies? check if it’s working?
i still dont know what goes wrong after power outage
Did your system have a static IP address? If not it may have went DHCP rogue on you and changed it’s address.
yes, sir, in my router settings, I have assigned an address for it like it always has. This issue will be solved if I manually restart HA, but I want an automatic solution in case power goes off again, and i am not able to find out what went wrong in the HA logs. Please help.
Alternate solution: Why not invest in a cheap UPS that will power your system for the few minutes the power is absent? Power your router and ZigBee hubs too.
My router is in another location, and this is not feasible for me atm, but will invest on that, too.
Now I am looking for a solution when system log shows ‘network unreachable’ then they will perform a Full Reboot
Does it take time for the ZigBee network mesh rebuild to happen after every power off? It might be exacerbating your problem if you were to make this happen deliberately and often, instead of tackling the possible underlying issues - unreliable power and poor network connectivity.
