Apple TV closed captioning toggle
I have the Apple TV integration installed through HACS and I have also installed the Firemote card. What I can’t seem to find is how to turn closed captioning on or off by setting up a simple toggle switch. Does anyone know how to do this?
Hello @berg0319!
I’m pleased to hear that you’ve installed my Firemote card!
Unfortunately at this time, it appears that the Home Assistant Apple TV Integration does not have a remote command to handle toggling closed captioning.
The best thing that Firemote can do to help is the Function: Control Center shortcut button.
There are still a couple more clicks involved to toggle closed captioning, but it’s at least a start.
-Doug
That helps. Hopefully that gets added one day. Thank you.
