Apple TV Integration - tvOS 15 Beta
Apparently broader issue, already discussed in main 2023.5 thread. Solution is to disconfigure and delete integration and go with the official one…
Yep I installed the official one and that works fine.
Where can I find the official Apple TV solution? The only one I see is in HACS.
Add integration then search for Apple. Apple tv is one of the option underneath.
I get this error when trying that one:
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble.
Yep I got that as well initially but it worked fine after removing the HACS version and a few reboots.
For me the old HACS version was not properly deinstalled and the files where left in the custom_components directory. I had to delete the complete folder to get the official version running.
I have the old integration deleted and have been able to add an airport just fine, I’m trying to add an apple TV Gen3 and I’m getting the add pairing code, then add dmap (remote) code just fine and then it is asking for a raop pairing code as well, which my apple tv just recycles the first pairing code and this errors out…any advice?
Edit: Turns out the next day putting in that same original pairing code for the raop code worked just fine!
