Yes!! Itās all working again! Thanks for the very fast response and helpš!
And I saw the new cycle counter option, nice!!
Although I have this setup and working of my own, I will check this out!
Btw, also in both yamlās (appliance and battery) there is this:
9+ occasions in each yaml. Do I have to do something about that? Or just leave it as it is? (Even after update to 2.8).
HA is adding it to my code when you import it. That is strange but that is the default value anyway. The funny thing is, I reported this to studio code server 8 hours ago as one of my blueprints use it.
Donāt worry about it as it is allowed and studio code server just has to update there side.
Blacky
Funny indeed, but ok, Iāll leave it as is!
Thanks again!
Thank you for your support
. Here the code. Seems OK to me?
By the way the consumption is also not show. Is says 2 times āVaatwasser is gestartā
alias: Vaatwas Notifications & Actions
description: "Tracks start and end "
use_blueprint:
path: Blackshome/appliance-notifications.yaml
input:
power_sensor: sensor.vaatwasser_power
start_appliance_power: 20
start_time_delay: 0.5
include_start_notify: enable_start_notify_options
start_notify_device:
- 6e314bf857e6f7c76814234d108ca0a8
start_title: Vaatwasser
start_message: "Is gestart. "
include_end_notify: enable_end_notify_options
end_notify_device:
end_message_title: Vaatwasser
end_message: "programma beƫindigd. "
include_power_tracking: enable_power_tracking
power_consumption_sensor: sensor.vaatwasser_power
end_message_kwh: "Verbruik : "
include_duration_tracking: enable_duration_tracking
end_message_duration_tracking: "Duurtijd : "
end_appliance_power: 10
running_dead_zone: 0
include_watchdog: enable_watchdog
watchdog_timeframe:
hours: 2
minutes: 0
seconds: 0
watchdog_message: Uh-oh! Time to check the dishwasher.
It should not do it but I do see that you have missed entering 3 helpers into Power Tracking. You will need to disable this option or enter in the 3 helpers
- Power Tracking - Cost per kWh
- Power Tracking - Start Number Helper
- Power Tracking - End Number Helper
the how to do this is here
Let us know how you go.
Blacky
Cool, understand it!
I will easily disable the power tracking as I was just curious and not really need for now.
Will see how it goes tomorrow!
Thanks for such a good support!
Gunter
Couldnāt wait . Disabled and did a quick test. Workās like a charm now!!
Thanks again!
What needs to be in the Power Tracking End Number Helper?
Exactly the same as in Power Tracking - Start Number Helper?
Just that it has two different names?
You may have a picture of the End Number Helper to illustrate this!
Thanks for your help ! LG BigDaddy
Welcome to the community.
Yes, you need 2 number helpers one for the start and one for the end. You also need another number helper for the Power Tracking - Cost per kWh. In total you will need 3 number helpers and the only one you can reuse in another automation is the Power Tracking - Cost per kWh helper.
Here is the link to the FAQ that shows you how to set it all up, click here
Blacky
I am able to monitor my water consumption and wonder if there can be added a extra tracking option like the power consumption tracking. Doing a meter reading at the beginning and at the end shows me how much water the washing or dishwasher has used. Washing machines and dishwashers have all kind programs like the ECO, this enables you to check which program is most efficient in power and water consumption. Just an idea
I was going to add this in the last update but I personal donāt have any water meter in HA. I did some research on them and I was going to ask the community on the entities they have and what is the most common vale they are measured in. I can see some real value in having it. To add it would be easy I just want to get it right.
Maybe if your keen and reading this you can provide me a screen shot of the entities you have of your water meters.
Blacky
Hi Blacky,
In my case I have a entity called sensor watermeter_consumption_day
At midnight this is set back to zero. There are different sources that can provide water consumption info like the HomeWizard watersensor. This sensor is mounted on a analog watermeter and reads a small wheel that turns 360 degree for each liter consumedā¦ The HA Homewizard intergration is available in HACS. Basically the entity are more or less the same.
I realize power plug sensing is globally is more or less the same.
Hi
The blueprint is great and custom actions such as announment on google hub works perfect. But when custom actions is set, the message to our mobiles does not work.
I have tested it here and it is working.
Could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on ā</>ā and paste code in there.
Blacky
Thank you for yur help
alias: Waschmaschine_Ende
description: ""
use_blueprint:
input:
power_sensor: sensor.0xf84477fffed15a06_power
start_appliance_power: 30
end_notify_device:
- f048c4c99ea7a07dddcd235498b8b76b
- f2a5ff81ec80f71fc6697d819f3de173
end_notify_data: []
end_time_delay: 2
include_custom_actions:
- enable_end_custom_actions
end_custom_actions:
- action: tts.cloud_say
metadata: {}
cache: false
entity_id: media_player.wohnzimmer
message: Hallo. Die Waschmaschine ist fertig.
power_consumption_sensor: sensor.0xf84477fffed15a06_power
end_message_title: Waschmaschine
end_message: Die Waschmaschine ist fertig
