Thanks for the great automation. I have just bought a new washing machine and dryer which actually reports the state of the device through a sensor i.e.running etc. I appreciate this could be picked up editing the YAML but would you consider and option to add other ways to identify the applince state away from power?
I have tested it here using your settings and it worked but not your not using the End Reminder Status and the End - Attended Status as these settings are in the End Notify section and your not using it so you only get the Start Status and the End Status.
If your smart washing machine or dryer reports its status through a sensor, why not use that directly?
If youāre looking to receive notifications based on those states and would like to use a blueprint, you may find my State Notifications & Actions blueprint useful.
If youād like to use this blueprint, you can create a Template Sensor helper that converts the applianceās states into numeric values. For example, set the sensor to 10 when the appliance is running and 0 when it is not running . You can then use this template sensor as the trigger for the blueprint.
Add the Cycle Counter helper to your dashboard. Once you have serviced the appliance, reset the Cycle Counter helper by clicking the Reset button, as shown below.
Add the Time-Based Service Reminder - Text Helper to your dashboard. Once you have serviced the appliance, reset the Time-Based Service Reminder - Text Helper by entering 0 into the helper, as shown below.
ha! thanks - i figured it was a simple fix - appreciate your effort and attention to all the things that need to work well to. make these blueprints awesome
i try to use your blueprint, but it donāt work for me. I get stuck at the same position as hansolu. It looks, like it doesnāt react. .
Should be below 15. Stays by 10 for one hour.
I found it myself. Just turn Start & End notification on
