https://imgur.com/a/yoV08pB is how I approach it. I also have two Alexa accounts combined, but because they share the same household, it ends up in duplicate messages, unless you use something like dropping a message.
[{"id":"7d72b9e8.14de78","type":"tab","label":"Drop Message","disabled":false,"info":""},{"id":"f073080b.a7cae","type":"change","z":"7d72b9e8.14de78","name":"Strip Wake Word","rules":[{"t":"change","p":"payload.description.summary","pt":"msg","from":"^(alexa )?","fromt":"re","to":"","tot":"str"},{"t":"change","p":"payload.description.summary","pt":"msg","from":"^(amazon )?","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":945,"y":199,"wires":[[]]},{"id":"7cde2905.64fb2","type":"delay","z":"7d72b9e8.14de78","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"2","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":745,"y":139,"wires":[["f073080b.a7cae"]]},{"id":"940bae50.427d4","type":"switch","z":"7d72b9e8.14de78","name":"Alexa hears","property":"payload.description.summary","propertyType":"msg","rules":[{"t":"regex","v":"alexa|amazon","vt":"str","case":true},{"t":"regex","v":"^(?:(?!amazon|alexa).)+$","vt":"str","case":true}],"checkall":"false","repair":false,"outputs":2,"x":525,"y":179,"wires":[["7cde2905.64fb2"],["9d206b72.b9ddd"]],"outputLabels":["Turn on",""]},{"id":"9d206b72.b9ddd","type":"delay","z":"7d72b9e8.14de78","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"2","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":745,"y":239,"wires":[["f073080b.a7cae"]]}]
