HI !
I have a few Aqara cams , after updating to iOS 18.4.1 the cams can stream at the HomeKit hub but won’t record , I tried to reset the Apple TV , the router , and the cams , nothing worked , what can I do to solve this one ?
thank you all
HI !
thank you all
This does not appear to have anything to do with the open source software: Home Assistant.
You should post your question on the Apple forums.
